IFTA? I think you mean IRP ... IFTA is just your fuel tax account and is not weight dependent. IRP is definitely weight dependent though.Make sure your IFTA is valid for the weights you are going to gross. Also ensure the axles and tires are rated for the weights you are going to be handling.
Thank you for the correction, I was just doing my quaterly IFTA filing at the time...IFTA? I think you mean IRP ... IFTA is just your fuel tax account and is not weight dependent. IRP is definitely weight dependent though.
As for the truck, 12's and 40's will be fine. Your trailer axles will pick up the extra weight. What I would be most concerned about is that 1) you have enough horsepower, 2) you have enough transmission, and 3) you have a heavy enough rear axle ratio.
A 375 HP DD13 with a 10 speed direct and 2.93:1 axle ratio will not pull 130,000 lbs gross for very long.
As long as all of it attached to a double frame, eh...
No as probably half of the local heavy guys are using used highway tractors that where a US Tandem spec. A lot of heavy steel etc is in the driver. Drive like an idiot poop breaks drive nice and smooth looking cool in you stool and all will be good.
