Toronto/GTA: Transload 24,000 lb engine from Flat bed into ocean ctr
JNS-Shawn
235
32
28
Hi all,
I am looking for a warehouse in the GTA that can transload from a flat bed into an ocean container and then do proper block & brace.
1 of the pieces is a motor 147” x 85” x 98” @ 24,000 lbs + there's a couple small skids.
If you also offer flat beds or do ctrs let me know, if not it's ok too, I have someone that can do the trucking parts..
Thanks!
** Edit - I should have mentioned they need to be able to load into a 40' high cube container
Hi all,
Thanks!
Pack-All International in Mississauga ON - they have bìg overhead cranes for that kind of weight and they do everything else you need
Bezco Trucking in Brantford has massive forklift. They unload and reload all the time . They might be able to do it .
There is a place in Bolton, On at 68 Commercial Rd. They used to be called HI-Tech and specialized in heavy towing. They are "go to people" for Richie's foreign customers when they need to take big stuff apart and load into marine containers. The best thing to do would be to call RB in Bolton and get their info.
