Insidetransport on your Blackberry!!!!!!
adminadmin is verified member.
Administrator
Jan 20, 2008
15,008
421
83
20 15 10 2 20 10 5 1
Away from the computer and still want to stay on top off things on insidetransport.com? Well download this program and follow some basic installation instructions and take insidetransport everywhere you go.
BlackBerry Install
OS 4.5+ and OS 4.7 Storm / Storm 2
Use your BlackBerry browser to surf to:
http://www.BerryBlab.com/
Once installed:
- Open the software - upgrade to a newer version
- Press the "BlackBerry Key" and select "Add Forum"
- Type in the full http://www.insidetransport.com
Setting Your BlackBerry's APN
Some users may need to setup their APN for their phone carrier / provider. An APN is an "Access Point Name" which is sometimes required to access unrestricted data networks on Smartphones.
A list of APN's for your carrier / provider can be found here: http://forums.pinstack.com/f24/tcp_apn_wap_gateway_and_port_carrier_settings-360/
  • On your BlackBerry, go to "Options" > "Advanced Options" > "TCP/IP"
  • Check the "APN Settings Enabled" checkbox
  • Enter the APN
  • If the APN requires a Username / Password, check the "APN Authentication Enabled" checkbox
  • Enter the Username and Password
  • Save on Exit
Setting Your BlackBerry's App Permissions
Some users may need to change their phone's permissions to allow the foursquare app to properly connect to the internet. If you are having issues signing into foursquare, etc. you can change your app permissions as follows:
  • On your BlackBerry, go to "Options" > "Advanced Options" > "Applications"
  • Scroll through the list to find the "BerryBlab" app
  • Hit the menu button and select "Edit Permissions" from context menu
  • Change the permissions for "Connections", "Interactions" and "User Data" to "Allow"
  • On exit, save the changes
any questions please post and will try and help
