P prsa New Member Feb 11, 2013 29 1 3 2 Nov 14, 2018 #1 Does anyone know a carrier that can do this lane? F/L-- Can go on either Van or Refer Thank you
Freight Broker Well-Known Member Sep 12, 2009 2,275 2,066 113 30 Nov 14, 2018 #2 GTL Transportation out of Dartmouth, NS may be able to help... 800-565-9376.
L Llama Member Oct 24, 2017 95 76 18 Montreal, QC 10 Nov 14, 2018 #3 Doug Demont's New & Used Equipment may be available as well 902-755-5543 speak to Evelyn
Rob Site Supporter Jul 29, 2009 3,515 4,274 113 Brantford On www.gavintransportation.com 30 Nov 14, 2018 #4 Get it up here and cross dock it to a Newfoundland carrier up here would work also. Reactions: markhamboy and MikeJr
loaders Site Supporter Feb 26, 2008 3,531 4,389 113 30 Nov 14, 2018 #5 If you take Rob's suggestion and get the shipment to the GTA, Terra Nova could take it the rest of the way.
Shakey Site Supporter Oct 4, 2010 2,548 1,432 113 Out and about like a rainbow trout seaboardtransportgroup.com 30 Nov 15, 2018 #6 Clarke Road or Rossignol might be able to do direct for you
D doubletime New Member Nov 16, 2018 13 2 3 2 Dec 4, 2018 #7 EASSONS TRANSPORT RUNS THIS LANE ALL THE TIME
E ed1 Active Member Jun 7, 2011 222 43 28 10 Dec 4, 2018 #8 Is it pods if it is it will require special handling
Parisite Site Supporter Jun 17, 2008 201 26 28 Eastern Oxford County - the best place on Earth www.allloads.com 10 Dec 4, 2018 #9 You can also arrange trailer interlined between two carriers if they both trust you enough to allow you to put it together. I've done it quite a few times.
