I have a question for more experienced carriers that might be able to shed some light on how to handle a difficult situation. The issue is when a broker sends a truck for a pickup - and the amount of freight the shipper intends to load is not consistent with what has been agreed on the load confirmation.
For example: if you agreed to take 25 feet of freight and they try to put 33 feet - you obviously have to revise the rate. But at that very moment you, as a carrier, are at the disadvantage at least from the negotiating point of view because your truck is already there and if you cannot agree on extra money you have to pull the truck out of there at your expense. Obviously, the load broker will blame the shipper and claim being misinformed and vice versa. That is quite often the case but sometimes I suspect that putting the carrier in that undesirable situation might be done intentionally to leverage a better rate.
As a carrier, I have been exposed to this situation recently and it seems that this happens more and more often as the rates do not reflect rising fuel prices. I suspect this issue is even more prevalent in my line of business which is flat bed services. Since most of the shippers and some load brokers have no idea or conveniently choose to ignore the standards for a load securement and think they can stack everything on anything to reduce freight footage and get away with it.
Your feedback on this will be greatly appreciated and surely help many caught in the same situation.
