Belleville, ON - Bronx, NY
ManU
150
I have 20 loads to cover this week (I know...good luck). Full 53' tandem van loads. 44000 lbs and skidded. If anyone can help or suggest someone, I would appreciate it.
Thank you
International Truckload Services is right out of Belleville, maybe they can help. Sunbury has trucks in Ontario quite often, and they run the greater NYC area. Hopefully you've got a good rate going there.. at least Bronx isn't Manhattan or Long Island... hey, look at the glass as half full instead of half empty. The big American outfits might also be interested too.. they don't need to load back to Canada once they're done with your loads. Give Werner Canada a call.
Thank you for the leads. Unfortunately none panned out. Understandably so given the location and short week.
Hopefully you get a few before too long. I move a lot of freight into Bronx out of other areas in the US, but not from Canada. I find that with NYC the tide does turn.. one just needs to be a little patient sometimes.
