Hey all,
Been doing a bit more work across regional and short-haul trucking lately, and I’m curious if others are noticing the same shift.
Even when freight is booked pretty cleanly (palletized, dock-to-dock, etc.), the actual delivery side seems a lot less predictable than it used to be. What shows up on paper doesn’t always match what you deal with at the door.
A few things I’ve been running into more often:
Mixed freight is more common now, not just clean full-pallet loads.
More places don’t actually have forklifts or proper unloading setups when you arrive.
Retail and secondary distribution routes especially seem a bit “assume nothing” these days.
Because of that, planning feels like it’s moving more toward flexibility than strict route structure. You can’t always rely on the same unloading conditions from stop to stop.
From an ops side, it’s also changing how trucks get assigned. You’re seeing more setups that can handle different situations instead of being optimized for one type of run. In cases where you don’t know if there’ll be equipment on site, having onboard unloading support (like lift systems) just removes a lot of friction. Not really about heavy freight—more about not getting stuck at delivery.
Curious how others are handling this:
Are you planning more “multi-purpose” trucks now vs dedicated use cases?
Is this mostly a retail thing, or are you seeing it in industrial freight too?
How much of this is messing with dispatch planning vs just becoming normal now?
Interested to hear how it looks from other regions.
