“Let an engine be an engine”: How International’s S13 redefines diesel efficiency
adminadmin is verified member.
Administrator
Jan 20, 2008
17,599
506
30 20 15 10 2 20 10 5 1
When International’s engineering team joined forces with MAN and Scania back in 2017 to design a new heavy-duty powertrain from scratch, they started with a radical design philosophy: forget about […]
Continue reading...
Fuel milage is great downtime not so great, 3 weeks to replace a rear accessory drive housing. REMOVE MOTOR TO COMPLETE THE REPAIR.
What happened to the UPTIME Program.
  • Porous Castings: Some leaks have been attributed to quality issues with porous castings in the rear structure housing from suppliers. This may require replacing the faulty housing or a specific repair procedure (like installing a sleeve for a pin boss issue).
I'm all for innovation but remember what innovation costed Navistar the first time around. Their no DPF solution was to increase the fuel rail pressure beyond maintainable levels. If you try to hold back that pressure constantly at some time, it's going to let loose. Their track record is a high bar to overcome because not only were they wrong, but they also didn't really come to the table to help many of those struggling with the issue.
Now they think that increasing burn temperature by increasing the compression ratio is a good idea? Then dosing DEF at two points? Sounds like the same setup as before. What could go wrong? Hotter engine core temperatures, quicker degradation of oil and coolant, heads and pistons fighting a higher compression and then DEF dosing at 1000psi+ in two places when they haven't mastered dosing it in one.
Then onto the after-treatment device - where are they going to mount that? In the trailer? And look at all those computers, sensors and wiring, all mounted on a box that is expected to accept the raised exhaust temperatures that is coming from the engine.
Sounds like a hung jury before judgment in my opinion. No thank you.
