Hi Folks,
Just wanted to get someone else's take on this one. Booked a driver on an OD load last week, driver gets shutdown 90 miles from the receiver (assuming the DOT pulled the plug) due to weather (heavy snow/blowing snow). I have several loads hitting this location, wide legal etc. Every carrier has called in identifying the delay, will check back tomorrow etc etc keep me posted. I get one O/O calling in demanding a layover? My issue is, my customer and I cannot control the weather, it's winter it happens. It would be the same as me calling and demanding a rate reduction because it is a day late, I am assuming the carriers answer would be the same he can't control the weather? Am I out to lunch? For the record the state is WY, it is well known to have these sort of shutdowns at this time of year, and the driver is from UT not like he can plead ignorance? It is also only 1 day in, and he keeps referring to 90 miles but won't identify where exactly that is. As an aside, I had a guy trapped out on the HWY last year for 5 days in WY, I did everything I could to make sure he was safe including telling him to leave the freight behind if need be. Any OD hauler want to chime in on this one? For the sake of the argument lets assume my rate was fair for the line haul, permits, tarping etc and go from there (it is hence why I moved more than 1 shipment).
